1 - 2 of 2 Posts
Hi guys
Just need some help regarding a Xenon headlight install.
I recieved the unit from a friend, works fine, just want to know how to connect it. The ballast box has a cable running to the bulb and then a red and black wire for power supply. Do I just connect the red and black to the wires leading to my current headlight connector jack?:O
Thanks in advance!
i would use a relay to protect electrical system...have the leads from original light activate relay. then run power for the xenon direct from battery through the relay
1 - 2 of 2 Posts
