turn the tickover up?
As the others have said, use the fast idle lever, or turn up the idle speed screw to increase the RPM. Then you can warm it up and look at a few things to establish a base line. If it wants more throttle, give it to it. Technically, you can't set the TPS until it is running on the warm map anyway.So .....
it will fire if I crack and hold the throttle, but when I release it will die. ...
Dealer mode shows c00, but my TPS bar is never in the middle (usually bottom). .....
