1 - 3 of 3 Posts
:banghead :banghead DID THE SPRING CHANGE, BUT WHAT A BITCH TO PUT LINKAGE IN. IT WONT GO? LOOKS LIKE I WILL ALSO HAVE TO UNDO THE OILINS REAR SHOCK LOWER BOLT :banghead TOP REAR BOLT GOES IN TO TREAD OK BUT AS SOON AS I FEED LINKAGE IN I HAVE TO HAMMER BOLT IN BUT WONT GO IN TO THREAD :banghead HELP????? :hail
Banned
Suspend the bike by the subframe, so you can move the swingarm up and down freely, you will find the right position, where it slides right in.
Clean up everything, put a little grease on the bolts & suspend the bike through the swingarm pivot & it will all fall into place. Hammering bolts into place on a motorcycle is a sin unless you are repairing a crash damaged bike at a race track under serious time constraints. You get a special permit in those circumstances...
1 - 3 of 3 Posts
