great article :hail
I have files for all the std TL cams so if you want to see plots just ask and i'll put them up. I can overlay the R and S plots over each other if u want to see the difference.I don’t have a plot of an exhaust camp ramp maybe sum one else can post it up
I just watched the "Nascar Dual Spring - Video of dual spring shown at 2006 PRI show (WMV format)"Theirs sum great video footage of valve springs in action on this site
http://www.racingsprings.com/movies.htm
Scary eh!Theirs sum great video footage of valve springs in action on this site
I'll look around for you.BTW Stu, don't suppose you can get Nuway valve cutting heads cheap :devious
Just looked here in the UK and nearly fell off my chair :banghead
Cf
Thanks for your comments.
FYI the data used was from a std TLR exhaust cam, all components were measured using industry std devices. and all assumptions were based on a std engine.
The resolution of the cam measurements was in 1/100ths thou per degree.(using a machine similar to the adcole) ( I service the machines so I'v had access now for ten years) files were generated using CamPro. and the analysis with Dr.Dr.
I think perhaps you might have missed some of the intent of the thread, which is to dispell some common myths associated with cams valves lash and springs.
We agree on what damages the buckets but not exactly the events that lead to that .
Yes it would be very helpful to have more collected anecdotal evidence and even more useful to be able to examine some failed components and the matching cams.
What is widely being assumed as the cause of these failures ranges from grit in the bucket bore to sticky valve stems. i don't believe that the buckets presented in the threads failed as a result of these conditions.
As to the complexity of the descriptions I give the zoners credit for being able to follow the gist of the thread if not all the detail. I could have made it far more complex but that would not have been appropriate.
