There are lots of threads asking about failed TL cam buckets and the most severe being ones with splits across the top of them.
It usually happens on the exhaust side and seems most prevalent on the front cylinder. More commonly it is happening in europe in places where there are unlimited speed restrictions.
Taking this into consideration and using some quite sophisticated measuring equipment and some clever software analysis I will endeavour to support my assertations that the problem lies in the cam / spring /rev relationship.
As I have mentioned in other places the role of the camshaft is to open the valve. The shape of the cam is designed to open it at a certain time to a certain height and for a certain time.
The role of the spring is to control the movement of the valve as it is acted upon by the cam. it holds the valve in contact with the cam as it opens, stops it overshooting the full open position and guides it back shut in sync with the cam.
the spring has a certain "spring rate" that is how springy it is and this is measured usually in pounds per inch.
The spring also has a natural frequency. If you pluck a guitar string it produces a sound, pluck a thinner string and the sound is higher. it has a higher natural frequency. spring frequency is a product of design and material. some materials have higher frequency some shapes have higher frequency. less coils per inch = higher too.
Cams are measured on duration , how long they are open. lift, how far the open the valve. and lift per degree (accelleration) how far they lift per degree of rotation.
Within each of these considerations are the subtleties of design..
A spring has to be the right dimension to fit in the space available and strong enough to do the job. it has to have a frequency which is suitable for the application too.
The camshaft has to open the valve gently and close it gently. we don't want the valve train subjected to the valve being banged open or the valve slammed shut.
banged open is known as 'jerk' . slammed shut is known as "seating velocity"
Cams have opening and closing ramps. (for the slow start / stop bit) flanks (these do the work ) and the "nose" ( where the valve slows down , stops and starts to close).
Good cam design takes these components and does them in harmony with the air demands of the engine and the cylinder head design.
Any overhead cam bucket cam profile will work in a TL, whether it accomplishes the desired outcome is a totally seperate consideration.
does it have the right lift, duration or area under the valve( the combination of area and time , it equates to how big the valve hole is and for how long).
Lift, duration and area all influence the characteristics of the power produced. but that is the realm of another thread
We assume that these things are done for us by the cam designer or the engine manufacturer.
It is all a compromise. and in some cases it is not proven in testing. As a former engine reconditioner and cylinder head specialist and now as a computer support techie for some clever engine developers and a cam designer I see many cases where cams are just "knocked out " with little or no thought to the interaction of components in the valve train and the consequential damage.
In the next post I will display a cam plot and explain the various events on the graph..
