After noticing my TLR leaning over farther than normal when on the kickstand, I decided to check it out. I was glad I did, the kickstand bolts were a few miles away from vibrating out. :O In all my years (Not that many) I’ve never had to check or tighten kickstand bolts:confused Then again I’ve never had a TLR before either.
This happened to any one else???
All the time :)
WHen you replace the bolts put some loctite on them to keep them in place.....
:stupid locktite is your friend my friend :)
yeah i am finding this out myself. the funnest one was when my kickstand kill switch vibrated off the bike mid hard corner at 90+ scared the shit out of me when the bike just sunddenly died like that and of course trying to keep it on the road was fun. going from a good smooth fairly hard rollon at the end of the apex to sudden full engine braking was quite interesting to say the least
LOCTITE BLUE. not the red... blue will let you remove it when YOU want to. :) Damn, i had better get that done to mine... never checked my stand bolts. Dooh.
Part of the regular maintenance schedule with this bike IMO is to go around with a set of wrenches & check the torque of fasteners periodically. My TLS bolts do loosen up & I really do not like using Loctite everywhere. Kickstand bolts & muffler clamp nuts & bolts are ones that seem to loosen up just a bit over time. So I go around every few months with those wrenches & check torque & it is a good time to see if any leaks or other issues have cropped up. That is one reason I like my quick release fuel tank pins. I needed to check out where my horn wires were as I pushed them back in the wiring loom several years ago when I got serious about turning that thing to a track based bike. The horn was in a bad spot IMHO given it was run regularly in very hot conditions on a track. While under the tank I did my usual look around stuff & found one of the rubber plugs that I used to seal up a throttle body spigot (smog hose) had fallen off. The bike had been running marginally worse but I thought it was probably due to the much cooler weather we are getting. Nope.
