What mods do you have?
It's popping when coming off the revs. That's not the bit that bothers me though, it's the flat spot. Seems to get worse the more often I use the bike then if I leave it for a week it's all right again. Really weird.when you say backfire do you mean popping when you roll off the throttle and coming down the revs? if so thats the rear exhaust gasket
if its popping when you throttle on and its popping in the throttle bodies you need to set the throttle position sensor and balance the throttle bodies
Checked that and can't find anything. Even had my mechanic give it a once over and he couldn't find anything.air leak on pipes for back fire
dyno bike at malton can do it with a yosh box or a similar thing but seen as though you have ordered a PC get him to set it up he knows his stuff on the TL just ask sam!!
I'm putting money on the rear exhaust gasket leaking though
That's where I'm booked in, was recommended them by a mate who works at Transit bikes in York. Think it was Paul I spoke to?dyno bike at malton can do it with a yosh box or a similar thing but seen as though you have ordered a PC get him to set it up he knows his stuff on the TL just ask sam!!
How about quarter mile times? I do a bit of run what ya brung at York Raceway, my best time on the TL is 11.5 secs and would love to shave a bit off thatYou may not actually gain any more power or speed, it will seem like it though as you should find that it will simply run a lot smoother and pick up better, also it should be better from low revs,
Next Saturday. Can't bloody wait as we're getting the occasional sunny day here and there now and itching to stretch the TL's legs. At the moment even the run up to work is a bit nervous since the powers not always there when you want itnice one
when are you there?
I need to get mine in really!!
I've been trying to get it sorted, resorted to forking out for the power commander and dyno since all else has failed. Gave it to my mate who is a mechanic who used to work for Suzuki check it, and apart from cleaning out the air filter and putting in new plugs, he couldn't find anything wrong.if theres power not always there and feels flat I would start looking for whats causing it before the dyno run!
theres something not right if its flat sometimes!
check your clutch switch isnt sticking for a start as this will make it stay on the neutral map and will feel flat
also have you got a TRE fitted if so check connections out if the earth has come off it can make it go to neutral map too mine did this the earth got broken some how and was really flat (97 s with the separate earth lead for the TRE )
Fair play mate, like I say just getting desperate. Want it sorting and this was the best advice I had given what I'd already donepersonally I think you are pissing in the wind with the PC and dyno at this moment in time
the bike will run cock on without the PC although the PC will be an improvement to the power delivery
it should still run pretty nice
you havent wasted money buying the PC but you may waste it on the dyno if the bike isn't running right to start with![]()
