What is the best stuff for cracked plastics repair/strengthening??
Fibreglass i take it? Never used the stuff.
OEM ? Factory plastics are ABS. Use ABS adhesive
The ABS adhesives work very well. If the crack is such that it needs reinforcement, a scrap piece of ABS (from an old fender or fairing) can be used as a backing. Just don't be overly generous in the application of the adhesive, because the solvents will soften - and possibly deform - the surrounding areas.
Whats wrong with simply getting it plastic welded,fairing on this thing was done years ago and hasnt come apart nor can you tell its been done fron the outside,cheap as chips and any panel beater will do it.
