1 - 20 of 30 Posts
So I wanna do everything to make the beast breath better, right. Of course, so what is the best filter to use? I've used [email protected] before, but I've read how great this BMC is. Or is there something else out there?
I know enough of you out there have tried just about everything, so what is your opinions?
Pipercross :yes
BMC has a greater area than the K&N but the Pipercross has the most ... I noticed the difference :yes
For a TLR the Pipercross is the best I have seen. They are a company from England superior area from either the KN or the BMC, the BMC I saw locally was very poor in its ability to seal against the airbox as the plastic frame is way too flexible.
Pipercross foam filter replaces not just the filter but also the top plate the filter mounts to, and is like doing a Joe-V mod and better filter, yet is fully reversible and you don't have to cut up your top plate.
I've used both, but found there's bugger all difference if you don't have a modded airbox. Spend the time and do that if you haven't already. A dremel from harborfreight for $6, and some F/Glass from Advance Auto for $10 will do the trick.
kiwi
Pipercross IS the way to go. You can cut up your airbox and fit a K&N .. But as Cycle said the pipercross way is reversable if you sell up.
I always used K&N filters (Car & Bike) but the dyno dont lie .. I got extra ponies from the Pipercross over the K&N. When you see it you will see why .. its huge !! The removed plastic is less weight to carry around and the induction roar ... :drool
:hail TLR's
For the TLS guys the Uni filter rocks:thumbup
I went to the Pipercross website and it shows that they only carry the filter for the 97-98 TLR ? What gives ?
I want this product !!!!
1 - 20 of 30 Posts
