Chain?
  • 530
    Votes: 277 68.9%
  • 520
    Votes: 113 28.1%
  • I run another size
    Votes: 12 3.0%
  • Total voters
    402
21 - 40 of 142 Posts
520 is the first thing I do to a bike besides hack off the rear fender.
I've never had to adjust my chain either.
kman066, I'd like to advise you against the Vortex sprocket. My R6 ate one up in 4k miles. Get the Sprocket specialist Stealth sprocket. steel teeth with an aluminum carrier.:hail
For the racetrack, 520
DID X-Ring all the way.
We've tried them all for endurance racing, and nothing has lasted nearly as well as the DID X-Ring chain.
For sprockets, I like Sprocket Specialists hard anodized or AFAM. Excellent endurance results with either
T
Guest
Well, you're there-so whaddaya got? Wouldn't happen to still have a sharkskinz airbox would ya?:)
Nope, sold the airbox with the motor. Still have adjustable billet triples, radiator set, axles, calipers, motor with bad 3rd gear, and lots of little parts. And a full-on race TLR. I'll list everything later on the classifieds with part #'s.
just ordered my 520 RK chain and sprocket specialist 17,41 set up. 300 bucks canadian list.. we'll see what i pay.. :)
I also just ordered an RK gold x-ring 520 with 17/41 Stealth Sprockets.........should be here soon.....he said he has more in stock...Sprocket Specialists are the bee's knees :hail
520 ERV2 17/41, titan tough.
Had the aluminum Vortex sprocket on for over 8k miles and no signs of excessive wear. In fact, my original one with 3k miles looked worse than the Vortex one does now. Maybe you got a bad one, or I got a good one, but I'm happy. I was worried at first getting an aluminum sprocket for wear but it looks fine. At the time I got it because it was cheap, but it works and why change what works. Also, having the chain out of adjustment can chew a sprocket up real quick. I adjust mine once a month. It only takes 5 minutes. It usually doesn't require anything though.
Plus the vortex looks cool with the little waves/flares engraved into it on the sides.
T
Guest
If you look really close you can see the water droplets on the can.:yumyum
