Various TLS upgrades
2878 Views 13 Replies 5 Participants Last post by  Perky
Last few items I bought to upgrade the TLS.
Brembo 19x18 MC - Comes with rebuild kit as there is a whole in the rubber (Costing over £40 on its own). £200 ono
GSXR K1 1000 welded to match TLS layout - willing to let it go for the welding work alone - £110
Fully unrestricted centre pipe, lovely and piece and will be a great upgrade - £100 ono
In the next few weeks my fairly standard TLS will be up - So keep your eyes open :devious
Any chance of some more pics and details of the welding on the arm, and how much benefit is the header pipe.
Thanks
J
Hi
Do these bolt on standard TLS header (down pipes) ?....
Bagsy the centerpipes if you will ship to France.
Hi
It goes straight on the back header but you'll have to be a little inventive (cut and shut or use a SV pipe?)
I'll find the postage price for you and come back...
Hi
Ok.Thanks...
Do the center pipes end where the standard ones would of ended (towards the side of the bike ?... i'm guessing the dia are very near the same.
Thanks
J
Hi Matey - The arm is a GSXR K1 1000 swingarm. I took my TL arm off and got a local welding company in Burton called PH Fabrication, who do structural engineering projects and they matched them. They had to cut and weld a flat plate and eyelets.
Ok.Thanks...
Sort of - side exit (both sides of bike as standard) but sleeved pipe not bolted/plate so will need a link pipe to the can. Think they are 50mm, but can check.
thx, if you would pls.... Anyhow pls contact me : [email protected] with shipping cost / paypal invoice etc.....
cheers
Apologies for the delay - mad few days/weeks...
Please see attached more images of the swingarm...
Hi
You would need to find or make a front header pipe and mid pipes for this to work. If you made your own you could probably set it up to work with bolt on cans or stock cans.
Basically you would need everything you see here (parts not seen in the seller's picture) to make it work. Mids were on sale on ebay through LP Closeout, they might have more that aren't listed. £100 is cheap for what you're getting, but be aware most of the parts are NLA from the manufacturer and would need to be sourced or made.
Reactions: 3
Cheers matey - Currently still for sale. Please PM or reply here if interested.
B u m p :)
Spent all my dosh now... If you still have it in a month or so try contacting me again.
Have a good new year
Hi mate did you have this custom made? Im after a two into one front any ideas?
Regards Karl
