broken upper/headlight wiring harness
Any one have busted upper wiring harness that still has the socket that plugs into the gauges.
If anyone has one please let me know so I could buy it and repair mine.
Thanks Ninforus:)
Discussion Starter #2
"bump"
bump
I have one minus the Relay and fuses, not damaged and would have to post from UK if you don't find one locally.
TLS Plug is the same but the wiring is different as the TLS clocks don't work on the TLR etc
If you can get the pins out of the connector block carefully then you're laughing :laugh
i have a plug on the way so i can try to fix mine but if it doesn't work out i will get back to you guys for sure! thanks:)
