1 - 12 of 12 Posts
Massive thanks to everyone who chipped in on my build (and espeically Six5), I'm going for an MOT next week so I'm sure I'll have some teething problems but for now it's sort of complete
So I bought a bike blind and it had a known bad engine (TL1000S), I found a horror show of wiring and the bodywork was ratty. It was also modified for disabled use, it wasn't as nice as I had hoped to be honest
Getting the old engine out wasn't too bad although a few challenging bolts like the exhaust were fun
To switch to the TL1000R (thanks to a very kind local guy for a cracking deal) I needed to:
1. Change the inlet rubbers over (you need to keep TL1000S throttle bodies to fit in the frame)
2. Repin the plug for the gear position sensor (all loom was present already)
3. Use the stat housing off the S engine
4. Use the breather hoses off the S engine
5. Change the sprocket over (16 vs 17 teeth on the engines I had)
6. I had to extend the exhaust out and down, just welded in two sections near the front
Discussion Starter #2
Also modified the cooling system to use the water cooled oil cooler set up on the TL1000R rather than the seperate cooler on the S
I had a host of wiring issues not least of which were the randomly cut wires but also the starter relay and rectifier were both bad (common faults by the looks of things)
The connector by the handlebars appears to be another known weak point, mine was no exception, all cleaned up and repinned a couple to get this going
Then into the good stuff, fork rebuild with new friction materials and seals etc.
New wheel bearings whilst there
Various skulls were removed!
Discussion Starter #4 (Edited)
My clutch actuator only had two ball bearings left so this got renewed!
I decided both brakes should make the brake lights go so new pressure switch in the back line
Did my first stainless welding on a crack on the exhaust
New clock covers were fitted
All the frame and suspension got refreshes with new rose joints etc.
Fairings got cleaned, debadged, some rebadged, some painted
New lights in various spots including DRLs, fancy sweeping indicators etc.
Front screen stickers were removed and changed to just Suzuki
And this is her as she sits today:
(y) Yep. Well done.
Reactions: jseaman
That is a lot of tinkering. Glad it will be on the road soon. 😎
Indeed. I think he might have enen moved into puttering. :D
Reactions: jseaman
Discussion Starter #12
Oh I converted it to 6 pot calipers too, forgot that. Last night I fitted a new clutch cover so today got it fully up to temperature for the first time, seems sweet. Just looking forward to riding it in a few days now!
1 - 12 of 12 Posts
