1 - 2 of 2 Posts
Okay - I went nuts and ripped everything apart. I was gonna order the smart TRE but when I got in there, it was already installed. It's from Ivan's performance. Weird thing is - it's supposed to help w/ hard cold starts, right? It's summer - why do I still have to crank 4-5 times to get it to start? Also, is there a standard setup for idle? TIA!
If the clutch lever is pulled, I believe the ECU ignores the Gear position sensor information anyway, so a TRE shouldn't have any affect on the starting. But when running and you let the clutch out, it will have an affect on the idle.
Watch, this. Clutch in, same as no TRE, clutch out, TRE effect. http://wotid.com/pictures/albums/videos/clutchsw.wmv
1 - 2 of 2 Posts
