you probably left a shim or 2 out in the box
Since Stu guessed your problem before you admitted it :hail I will answer for him (he is sleeping with his teddy bear collection right now :rotfl ).Hi
I forgot to mention that there was actually a shim left out, I don't mean
To sound stupid, even though I probably will, is the transmission that sensitive to spacing etc?
Stu,the early and later cases have different thickness output shaft bearings behind the sprocket. ( wider bearing )
another place you could have excess sideplay if you got it wrong
Not that it has any bearing (<=== I kill myself! :laugh )
You are just mad because the voices in my head talk to me and not you. :rotfl:banghead Now, what did I do with that BAN button... :laugh
