I was wanting to see if anyone knew of way to set my TPS without the instrument panel. I'm getting a terrible stutter on tip in. I've balanced the throttle bodies and still have a miss. Unfortunately during the rebuild/ repurpose I removed the busted instrument panel and have no way of seeing the "Lines" to adjusts my TPS. Any help is greatly appreciated.
I was wanting to see if anyone knew of way to set my TPS without the instrument panel. ......
The thread linked below doesn't give the exact TPS voltages for your TL, however it does provide the measurement points and the sensitivity you can expect to see on the voltmeter. Have a look at it. It should get you in the ballpark.
I'm sure someone has posted the voltages over the years, it's just a matter of finding them.
TPS made easier (maybe)
According to my test setup, "-C00" (TPS ok) is at about 1.107 Volts. Jumps to 'LOW' at about 1.073 Volts, and jumps to 'HIGH' at about 1.118 Volts. All voltages measured with motor stopped, at the TPS plug between Gr and B/Br. I usually set my TPS to ~1.108 Volts. Measured TPS voltages also depend on the actual +5V voltage (R to B/Br). On my test ECM it is 4.95 V.
Hope this helps...
65811
65812
65813
This is great! Thank you. @JoE. were these readings taken with the throttle plates fully closed (idle screw completely out) or at idle?
As can said and can be seen, measurements were taken on my test setup so there is no throttle. However, the setup is equivalent to 'throttle at idle position'.
After I responded I realized you had already answered my question. Thank you very much for the help.
