1 - 3 of 3 Posts
I'm just trying to refit my S exhaust onto the R engine I bought and I'm having issues getting it to line up, is the angle of the heads the same? I have used the 'downpipe'/stub from the S but the angles all seem a bit off to line up the front and rear
The exhaust angles at the heads are the same.
Are you using an OEM exhaust? You may need to loosen the center coupling where the front and rear headers join.
OEM front but custom rear, it seems they are at different angles to avoid oil coolers? Either way I've cut it and sleeved two additional pieces in and just finished mating it up
1 - 3 of 3 Posts
