1 - 13 of 13 Posts
From post #7
Item listed, then quantity, then price per item. I have other odds and ends as well just didnt feel like listing them.
tlr
rear axle $20 (2 w/out adj. Blocks) $30 (2 w blocks)
front axle $20 (bare) $40 (spacers etc)
rubber tank mounts x2 $20
throttle bodies + inj.x4 $150
coolant res tank $20
starter motor x3 $60
kickstand $40
frame x2 $300/$700
faring mainstay $100
sprocket cover $30
right handlebar switches$40
coil packs $70
triple bottom x2 $70
windscreen green $30
choke cable lever x4 $20
engine parts
cam chain guide $30
cam chain tensioner $30
oil pump $30
flywheel rotor x2 $50 good cond. $70
cylinder head jug rearx2 $100
cylinder head jug front $100
engine mounts $40
trans shift forks $50
tls
front axle x2 $20
rear axle x2 $25
forks $200
front seat $70
kickstand $20
l handlebar switches x2 $30
r handlebar switches $30
coil packs $50
shift pedal+link $50
carrier hubx3 $30
r. Rearpeg+ barcket $30
side stand switch $20
sprocket cover x2 $30
starter motor x4 $80
thermo housing $20
t.b.'s + injectors x2 $150
throttle cables x3 $20
t.o.s. $20
triple stem $70
w.p. Cover $20
rear caliper $60
sub frame x3 $100
black tank $100
rear brake rotor $70
brake lever $20
k&n airfilter $40
rear brk master+ res $50
clutch lever $20
seat latch + cable $20
left ram air tube $30
right ram air tube $30
front brk master +res $70
fuel line x2 $20
tank bracket x2 $30
rad hoses $30
rubber cush drives $20
engine parts
oil pump gear $25
oil pump $30
gear selector shaft $20
flywheel rotor $90
clutch cablex2 $20
cam chain tensioner $20
valve cam cover $70
rear head valve, shafts + cams $150
rear cylinder jug $100
tlr
kickstand $40
frame x2 $300/$700
sprocket cover $30
coil packs $70
engine parts
cam chain guide $30
oil pump $30
engine mounts $40
tls
front axle x2 $20
rear axle x2 $25
forks $200
front seat $70
kickstand $20
coil packs $50
carrier hubx3 $30
thermo housing $20
t.o.s. $20
triple stem $70
w.p. Cover $20
rear caliper $60
sub frame x3 $100
black tank $100
brake lever $20
k&n airfilter $40
clutch lever $20
fuel line x2 $20
tank bracket x2 $30
rad hoses $30
engine parts
oil pump gear $25
oil pump $30
flywheel rotor $90
clutch cablex2 $20
valve cam cover $70
Discussion Starter · #10 ·
i cant edit this thread but... i am going to repost a thread for the frames seperately as i listed them improperly.
Discussion Starter · #11 ·
also
2006 sv 650 front wheel $260 shipped +$ for overseas and canada
2006 sv 650 rear wheel $110 shipped ^^ ^^
2002 sv 650 rear wheel $140 shipped^^
2004 sv 1000 front wheel $160 shipped^^
2003 SV 1000S thermostat housing $35 shipped^^
2006 SV 650 thermostat housing $30 shipped ^^
Dibs on the two above pending questions on the Planet where I also dibbed them. :)
1 - 13 of 13 Posts
