Whole bunch parts available, basically a complete bike minus a few things.
Located in Calgary AB, Canada
Shipping is at buyers expense.
Contact me for pictures please.
Here is the list so far. I may have more things available as I go through the garage and I will update as I go.
All prices are in Canadian funds, so that makes this a good deal for the US folks :devious
97 TLS motor, complete minus throttle bodies and boots, 2nd gear is gone or gear selection fork is bent, engine was running great when I removed, looking to get $400, can break if specific parts needed
TLR forks complete with triples, $300
2 x 1999 TLS dash - $100 each
2 x 1999 TLS headlight - $150 each
Stock exhaust complete - $250
1997 TLS oil cooler - $50
TLS Frame, unregistered, warrantee replacement, just needs to be stamped with new vin and you are good to go - $400
TLS/TLR/SV1000 rear rim, rotor, axle and sprocket - $200
1997 TLS seat, minor cut - $30
TLS rear swingarm – pieces removed to attempt a project - $50
TLS rear swingarm- painted black - $150
TLS stock undertray - $25
Complete 1999 TLS main harness - $200
1999 TLS ECU - $200
1999 TLS stock rear shock - $50
TLS SOAS x 2 - $50 each
TLS Ohlins rear damper - $400
Ducati 1098 rear shock, race tech internals and spring - $150
TLS Rear plastic, left and right - $100
2 fairing stays - $20 each
3 windscreens, 1 clear, 2 tinted - $50 each
Rear hump - $50
Front left and right fairings, some scratches, no cracks, complete with intake boots and turn signals - $200
Stock TLS steering damper, kit complete - $75
TLS/TLR mirrors x 2 sets - $50 each
turn signals x 2 sets - $30 each
stock passenger seat - $25
stock rear light - $20
stock brake hanger - $20
stock front axle - $20
TLS airbox minus filter - $50
Stock passenger pegs - $30
Stock rearsets - $30
2 TLS owner’s manuals - $10
1999 TLS throttle bodies with injectors - $150
TLS throttle body cables - $50
TLS radiator - $50
TLS brake reservoir - $10
TLS front brake lever and reservoir - $20
TLS kickstand - $20
TLS stock fan - $30
TLS stock sprocket cover - $20
TLS seat latches - $20
Fuel pump filter - $5
Aftermarket RR (not sure what as there are no markings) - $100
Stock rectifier - $50
Stock signal/horn LH controls - $30
Stock TLS coils and plug wires - $30
thanks in advance
Luke
1999 TLS ECU - $200
Rear hump - $50
TLS radiator - $50
TLS kickstand - $20
TLS stock fan - $30
thanks in advance
Luke
