The book says the Busa uses a 240mm rear disc. When I put gixer wheels and brakes on my R I kept the original hanger for the rear. I'm wondering if you could do the same but just swap the disk for a 220mm item.
I believe the bolt holes on the rotor are the same (external confirmation required). You might want to swap the caliper as well.
Take a look at:
http://www.tlzone.net/forums/perfor...-cheap-rear-brake-disc-rotor-improvement.html
and just as a shameless plug....
https://drive.google.com/file/d/0B_Pqm7oEcUniM1pRdlI3Y3ZabGFqU0xuSmFhQXRxeFVNRkxF/edit?usp=sharing
Take a look at:
