Hi mates,
I'm in the process to modify the TLS fork by using TLR valves + TLR spring + appropriate spacers ( like the ones used in Hayabusa forks as Old Doug Guru mentioned ). I also plan to " revalve " the original TLR valve . What would you guys recommend as the the correct stacking for the shims and what thickness should they mesure for track day purpose only. ( Please measurements in mm only coz i'm not familiar with inches...)
Thanks
Mighty_V2
Thanks
Mighty_V2
