Does anybody have a bare TLS frame at the headstock (steering stem removed) and who would be willing to get some relatively precise dimensions (mm)? I’m needing the distance between bearing race seating surfaces and the depth of each from ends of the headstock. Hopefully that makes sense. Ideally I’m trying to get the length between the bottom of the lower bearing and the top of the upper bearing.
Much appreciated
I have a set of Harris Performance adjustable offset triple clamp yokes being made, and they requested that dimension (from bottom of lower bearing to top of upper bearing) in order to make the new stem the proper length. If this doesn't work, they'll make the stem with extra length, and I'll need to determine how much to remove after an initial assembly.
Thanks again!
Matt
