i was wondering if you can fit the 97tls ecu to a tlr and would it make any difference??
:no, different plugs and wiring harnesses...
K but do they use the same sensors? or will the ones on the R not work?
i can change the pin configuration on the ecu plug to suit just wanted to know if it might give extra power(hehehe) or is it a waste of time for the R
The R has 4 injectors (two per cylinder), the S only two. No easy fit!
