I plan on leaving this world the same way i came in....... Bloody and screaming.
Mods (so far): Yosh full system with 20" CF cans, Power Commander 3USB, PiperCross air filter, Nology leads & profire coils, +positive mod, Rifleman 1/5th throttle insert, GIpro, Scorpio sr500i alarm, Tinted screen, Inline fuel filter mod, Pazzo shortie levers, Brembo 4pad calipers, Brembo radial brake & clutch MCs, AP mini rear brake caliper, Braking wavy rear disc, Pro Bolt Ti rotor bolts, Goodridge brake lines, Hayabusa forks with Traxxion 1kg springs, Carozzeria V star wheels, Ohlins shock, Ohlins steering damper, JMC swingarm, Powder coated black frame, 40tooth rear sprocket w/Speedohealer, Tech-G rearsets, Warp speed rad guards. Vandriver: +1mm swingarm eccentrics, Sprocket cover, Rear caliper bracket, CCC, pressure plate & rear brake res,
