TL1000R Part out 1998
Prices do not include shipping....
Plastics/Body:
Ram Air Tubes $45 pair
Ram Air Tube Boots $8 each
Electrical:
Speedo/Tachometer $80
Tail Light $15
Complete engine harness $90
+ & - wires off starter relay $5
Horn $15
Sensors/Switches:
Tip over switch $10
Sidestand Switch $10
Intake air temp sensor $10
Rear brake light switch $10
Right Hand Switch Block & Throttle Tube $60
Left Hand Switch Block $40
Ambient Air Pressure Sensor $10
Starter relay $25
Coolant temp sensor $15 each
Oil pressure switch $15
Clutch lever position switch $15
Speedometer switch $10
Brakes/ Suspension/clutch:
Rear M/C and Resi. $60
Front Brake M/C $75
Rear caliper $30
Rear caliper bracket $15
Complete Triple Tree $75
Engine & Cooling:
Left and right cases $75
Crank $175
Stock Airbox $35
Engine mounts set $40
Lines $25
Pair system $10
Vaccum lines & Dampeners $10
Valve covers (pair) $50
LH case cover $40
RH case cover $40
Cam chain $15 per
Magneto $50
Generator rotor $40
Thermostat (w lines) $ 40
Starter $50
Cylinder head cover bolts w/ oring (4) $10
Cam chain tensioner $20 each
Starter tourque limiter $15
Water pump Impeller $15
Oil pressure regulator $5
Oil sump filter $5
No 1 cam drive Idle gear sprocket $20
Primary drive gear assy $25
Gear shift cover $25
Gear shift cam plate/ gear stopper/ arm stopper assy. $40
Misc Items:
Swingarm Pivot Bolt $15
Shift Linkage $10
Passenger footpegs $40 pair
Left Clip-On $30
Right Clip-On $30
Sprocket sets $30 – standard
Fuel tank bracket $30
Plastics/Body:
Electrical:
Tail Light $15
Horn $15
Sensors/Switches:
Tip over switch $10
Starter relay $25
Front Brake M/C $75
Rear caliper $30
Engine & Cooling:
Crank $175
Stock Airbox $35
Lines $25
Pair system $10
LH case cover $40
RH case cover $40
Cam chain $15 per
Magneto $50
Generator rotor $40
Starter $50
Oil sump filter $5
Misc Items:
Shift Linkage $10
Left Clip-On $30
Right Clip-On $30
