Parting out a 99 TL1000R and everything must go except wheels and engine….Shoot me a PM if your interested
Body Panels.
Tail Fairing $100
Nose Fairing $75
LH Side $100
RH Side $100
Belly Pan $60
Front Fender $40
V Fairing $45
Gas Tank $150
Ram Air Tubes $30ea
Ram Air Tube Boots $10ea
Stock Undertail $20
Rear hump $75
Electrical.
Speedo/Tachometer $80
ECU $80
Headlight $130
Tail Light $15
Turn Signals, Stock $10ea
Complete engine harness $100
Headlight Wiring Harness $60
Body
Subframe $75
Swingarm $70
Brakes.
Front Rotors $75
Rear Rotor $25
Rear M/C and Resi. $60
Front Brake M/C $75
Rear brake torque arm $15
Brake Lines, Set, Stock $20
Front calipers $75
Rear caliper $30
Rear caliper bracket $15
Wheels & Suspension.
Rear suspension $20
Front Forks $150
Triple Tree Complete $75
Stock steering damper $20
Engine & Cooling.
Throttle Bodies $70
Stock Airbox $35
Engine mounts set $50
Coils $40
Lower Radiator $75
Upper Radiator with fans $225
Radiator Fans $25ea
Overflow bottle $20
Switches & Sensors.
Sidestand Switch $10
Tip Over Sensor $10
Ambient Air Pressure Sensor $10
Intake air temp sensor $10
Rear brake light switch $10
Right Hand Switch Block & Throttle Tube $60
Left Hand Switch Block $40
Other Parts.
Yoshimura RS# bolt on3 cans. $250
Front axle $20
Rear axle $2
Swingarm Pivot Bolt $15
Front Seat $30
Headlight Bracket $50
Passenger footpegs $40
Rear Sets $75ea
Lock set $80
Left Clip-On $30
Right Clip-On $30
Hydraulic Clutch, Complete Lever to Slave $75
Various Sprocket sets $30
Chain guard $10
Exhaust heat shields $25
Sidestand & bracket $15
Fairing brackets (small L shaped ones) $15
Im sure I may have forgotten a few things but let me know if you need something else..
