Hi All,
My TLR has GSXR clocks with all the normal problems. I going to rip them off and fit a spangly Mychon3 race dash but to do that, I need to convert the ECU-to-clocks serial data signal into separate analog channels.
It looks easy enough to do with a little microcontroller and will also give me a USB debug port so I can read the ECU channels (temp, revs, TPS etc) and fault codes on a laptop. I took a quick look with an oscilloscope and see 5 bytes of data (in normal mode)
Has anyone ever done this before and can give me any clues about the data format on the serial bus?
Cheers
Gadgeteer
There is a thread here on deciphering the ECU data.
Steve,
You're a star - thanks. Don't know how I missed that one when I was searching.
Let this thread die and I'll join the other one.
Cheers
Gadgeteer
