Hey gents thanks for all the help so far. I am replacing the gasket for my fuel pump and as a precaution I was going to add some gas/oil resistant sealant around the ****er to make sure it doesnt leak again. Is this a good idea or should I just bolt it straight on? Thank ya much.
Thanks. Will do:thumbup
Hi
I had to replace my gasket. I went without the sealant, it's a better seal. the gasket was designed not to have extra goo on it. It may leak with it. Just my opinion.
if u do use a sealant i would use the ultra copper or the ultra black and let it cure for about 12 hours before u ad gas
Make sure you torque it up correctly as the manual suggests. Iv'e heard if you don't it will leak again.
Also make sure that the surface is very clean, and that it is flat, no ripples or dents where the gasket goes. Plus I agree that you must follow factory torque spec's and tightening pattern.
ahem...
Discussion Starter · #9 ·
:hail :hail :hail :hail All hail Jasen!!!!!!! Getting my gasket and feul pump condom today. This is just what I needed.:bwtiller
I had mine out years ago, on the re-install I was careful about the tq, even re-used the oe gasket and still no leaks (knock on wood). If only my wp seal were as trouble free:banghead
I went through this nightmare. You HAVE to have a new gasket, and you HAVE to torque the bolts in the right order to right ft/lbs. It's EXTREMELY easy to strip the bolt holes out of the tank. It's odd because when you're tightening the bolts it seems like they're barely past finger tight but that's how it's supposed to be. I didn't use any goo and by doing it the correct way with brand new gasket it sealed up good.
