I'd recommend that you stick with the stock Suzuki fuel pump gasket, if you are going to use a gasket. Others have reported that they have had good success with a large o-ring. You would have to search for that, as I do not remember what size they were using. As for the rubber boot around the fuel pump, I took mine off and have not had an issue with it being removed.
