1 - 12 of 12 Posts
Like nothing I've ever seen before. Not interchangeable with the TLR.
Any additional info? Where did you find it?
NOTE: Only thing on the TLR with two prongs like that is the horn and clutch safety switch. And that's definitely not for the horn.
Hello TL Zone can anyone tell me what this part is please
It may possibly be the 3-pin side stand diode from a TLS. It appears to be burnt, so maybe the third pin is still in the loom connector. :O If it is that diode, it is normally wrapped into the wire loom behind the frame rail on the right hand side, near the area where your right knee would be.
A photograph with a size reference included would be handy. Maybe a common coin or something, to show the size of it.....
I think that diode is still available from the dealer. If not, there are aftermarket options available.
Yea Six5 you are correct it is a 3 pin and it is burnt out and third pin was still in there had to go back and pull it out
Well I'm still confused. Anyone got an image for one of these "side stand diodes"?
Josh,
You can "see" it labeled A in Crash's diagram. It is an isolation for the side stand and neutral off the GPI.
I can take you a picture, but it is quite boring.
Appreciate it. Just wanted to confirm it was TLS specific.
Well what the hell. I'm looking over my spare harness and see nothing like what is pictured there.
Knew I wasn't crazy :hmm
actually you are, :lol
remember when I told you about the led flasher unit for the tlr having more wires going into it, seven I think compared to the tls's flasher unit which has 2 or 3, now you know why :laugh
1 - 12 of 12 Posts
