Hi guys need some help ah hav 1000s leavein work one mornin headin home after niteshift on motorway checked ma mirrors and there was white smoke blowin out of the plpes an oil al over the side of the engine an ma boots any ideas if its oil pump or the water pump cheers pitbull
...... there was white smoke blowin out of the plpes an oil al over the side of the engine an ma boots ......
Welcome to the Zone Pitbull.
The oil PUMP is fine, but it sounds like you have an oil LEAK somewhere.
Have you located the source of the leak yet?
Which side of the engine is covered in oil?
Also, have you since then confirmed that smoke is coming out of the pipes, or is it simply smoking because oil is dripping onto the headers?
Oil on the left side of the motor smoke comein out of both pipes an when i got it home via recovery it sat till ah got time to check it out the motor started fine then was blowin white smoke out
where are you in the UK? Fill out your profile so we don't have to keep asking. There might be someone around the corner who can help.
Oil on the left side of the motor ....
On the left side, the common points for an oil leak are the clutch push rod seal and the countershaft seal.
Have you looked in the air box for excessive oil accumulation?
Is this a '97 TLS?
