1 - 20 of 44 Posts
Hey guys, looking at getting a pair of renthal sprockets and DID chain, what's the best sprocket set up known for the tls??
me thinks 17 front and 40 rear.
17/43
Tops out at around 160 if you ever managed to get it there, good acceleration without been too stupid.
I've allways liked. 17/40 have tryed 16/40 17/41/42 but for me 17/40 is what I like best
Cheers guys! Bit more of an idea, I want some rip your arms off torque bit not losing too much top end. Tricky one I know :-/
Whatever you decide try and avoid 16 on the front, that gives the swingarm guide a hard time :thumbup
I ran 17/40 for a long time then went 17/42. From memory, 17/42 makes 6th the same as 5th with std 17/38.
So if you can still ride it with 17/38 ride around in 5th for a feel for how 6th will be.
I fitted an 16 front sprocket (cheap fix, yeah I'm Dutch :)). 20-25k kms ago. Swingarm guide is still ok, but it is point of regular attention.
does 17/40 work with standard chain links on tls ???
No, stock chain is 104 links (17/37 or 17/38)
16*42 for me!!!!
17/40 worked okay for me with standart links number (104) :O
Wouldn't want to argue with Sam, but I was sure you could go 17/40 on the TLS with the stock chain. :confused
1 - 20 of 44 Posts
