can anyone tell me when you want to say run the bike and access the fuel adjustments ie; sync of throttle bodies, do you extend the fuel pipes and just hang the tank higher to allow for engine running adjustments or what. any help appreciated. regards al
You use the included tank prop rod to hold the tank up (or equivalent if yours is missing). Download the TPS setting video from the file vault for a visual...
Little tip for you - if you ever do remove the tank, the little rubber caps on the ends of the tank stay can be removed, and used to plug the fuel line, so you don't have to empty the tank; just have it ready and be quick - you'll spill bugger-all gas:).
