I was riding down the road & had to slow down for another car & throttled back up & the bike just shut off without warning the engine oil light came on & I couldn’t get it back started. ....... the fuel pump is kicking on & it will try to start it just won’t fire over.
Given the manner and abruptness in which your TLR stopped running, I would suspect a fuel delivery problem. You don't mention it, but if the external fuel filter mod has been done, it's possible that the fuel line inside the tank connected to the pump has dislodged. If that's the case, the fuel pump will run (which you confirmed), but it cannot create pressure in the fuel rail because the line is disconnected inside the tank.
Fuel delivery can easily be verified with the 'fuel volume test' on page 4-51 in the service manual.
The fact that the red LED illuminated (oil light as tlsgazza noted), and you were able to crank it over afterwards, says that the initial problem was most likely not electrical.
Thanks I think I found what it was after I got it home the next morning I had a trailer with fuel all over it so I’m thinking it’s gonna b a fuel issue hopefully just a line
Haven’t had one sign of any more fuel leaking.
What was the source of the fuel leak? And what did you do to fix it?
Of course, there could be other problems. If the fuel system is actually delivering fuel to the injectors, you will need a new set of spark plugs, because the existing ones are likely fuel fouled now after the many attempted starts.
