Ok, I have another thermostat. I want to test it before I put it in though.
Anyone know what temp it should open at?
Is this still the case? You cannot force the fans ON?If I short the terminals in the plug to the lower rad sensor the fans do not come on.
Ok, I just shorted it with a wire, with the ignition on, and the fans ran.Is this still the case? You cannot force the fans ON?
Ok, so I did this.... the bike cools down just fine and the fans stay on as long as I short the plug.The next thing I am going to try is to get the bike to 218 and then run the fans manually by shorting the connector and see if the temp comes down....
Your test basically proves the integrity of the fan circuit. :thumbup That's good.Ok, so I did this.... the bike cools down just fine and the fans stay on as long as I short the plug.
Now, when I short the plug, this will use all of the electrical system required to run the fans except for the switch in the lower rad.....correct?
So, if that is the only part left out of the equation, does that mean that the switch is faulty (I have changed it, but I replaced it with a used one...it could be faulty too)?
Good enough for an experiment. :thumbupI could tape a thermometer to the side of the rad...good enough?
Sometimes I think I just confuse the issue, but eveyone seems to tolerate it, so I'm happy to contribute to the chaos. :laughOh....and thank you for the help.
Without it I would have lost my cool by now! :lol
