TL1000R ECU teardown and repair C41 defect
584 Views 12 Replies 4 Participants Last post by  oszitrek
10
Hi All TL Fans,
I bought 2 defect TL1000R ECU with C41 failure code(FP Relay circuit malfunction).
My work, find the defects(test and debug eng.), and I thought we'd fix that too.
First Day:
Test the ECU on my TLR
See the C41 defect code, the fuel pump not working because the fuel relay not active.
Speedometer Motor vehicle Light Gauge Odometer
Let see what's in it:
Font Grey Black-and-white Style Rectangle
Output device Audio equipment Gadget Gas Rectangle
The first mark, this is not it won't be easy...(glass or crystal stone in the silicone)
Hood Automotive tire Automotive design Motor vehicle Vehicle door
Remove the back side of plastic box
Rectangle Tableware Dishware Recipe Metal
Remove the silicone with some tools
Grey Tints and shades Monochrome photography Monochrome Concrete
Liquid Fluid Rectangle Glass Tints and shades
Rectangle Font Tints and shades Jewellery Ceiling
Rectangle Material property Font Tints and shades Art
Light Automotive lighting Wall Rectangle Tap
1 - 13 of 13 Posts
Clean the PCB, of course the defected parts not here in the bottom side of PCB... o_O
Circuit component Rectangle Hardware programmer Font Computer hardware
Second day:
Then, cut again the top plastic case, and remove the top cover.
Gas Screwdriver Flooring Machine Asphalt
Input device Font Material property Gadget Office supplies
I SEE YOU! :) Here is the capacitors top, and the microcontroller.
Rectangle Tints and shades Font Monochrome photography Metal
Third day:
Remove the glass or something with My Friend. This is one day work:
Circuit component Passive circuit component Hardware programmer Rectangle Computer hardware
Rectangle Grey Font Pattern Art
Rectangle Electronic component Font Electric blue Fashion accessory
Fourth day:
Remove the side plastic, and clean the top side of PCB.
Passive circuit component Circuit component Hardware programmer Computer hardware Microcontroller
Bottom
Circuit component Electronic component Hardware programmer Computer hardware Font
Search the bad component. I find it 1 minutes.
Circuit component Hood Electrical wiring Electronic engineering Hardware programmer
Plastic box reassembly with soldering station.
Grey Rectangle Gas Graphite Wood
Rectangle Tints and shades Composite material Monochrome photography Shadow
Rectangle Grey Gas Gadget Metal
Rectangle Grey Composite material Font Tints and shades
Computer keyboard Input device Netbook Peripheral Grey
The information.
I change the defected transistor, and the ECU work again!
Passive circuit component Circuit component Hardware programmer Microcontroller Computer hardware
Vehicle Speedometer Motor vehicle Odometer Gauge
What a job.. very impressive!
Seriously...
This is awesome. Above the head of the average Joe, but amazing none the less.
What transistor did you use to replace? Now that you know what to replace, you could offer this as a service. What do you use to clean the board? Acetone?
Hi All TL Fans,
First Day:
Oszitrek,
You are one determined operator! Kudos to you for taking on a very daunting project! Obviously, this is not your first rodeo.
I am impressed. Wow! (y)
It's difficult for my old eyes to read the red text notes on the green, jumbled background of the PCB, but I appreciate your efforts to document it.
As rxf610 asked, what type of transistor is used to drive the fuel pump signal?
Also, as rxf610 noted, if there were an easier, more efficient way to access that transistor, there are many TLR ECMs floating around that could benefit from this fix.
Again, nice work!
Seriously...
Hello RXF610,
I use the original transistor.
The SMD marking is GA and this marking is a HE1A4A NPN transistor.
Board cleaning for the most part mechanical, and sometime washing isopropyl alcohol.
Oszitrek,
Again, nice work!
Helo Six5,
Thank you for the praise. :) Yes, this is not the first ECM which I repaired.
Editing one better paint for You. ;)
In progress one helper pack for homemade ECM repair.
1 - 13 of 13 Posts
