are the connectors that plug into the back of the tlr interchangable with a gsxr?:O
Which connectors? ECU, Lights, Dealer Mode switch, TOS :O
the connector that plugs into the back of the gauges.
Aha, not exactly. Do a search for gixxer gsxr guage conversion. You'll find all you need. You can get it to work with a gixxer guage on a TL, but you'll lose the temp indicator, but there are aftermarket ones available.
i don't think we are on the same page. my upper wiring harrness is broken ,it's missing the plug that plugs into the gauges so my question is can i use the plug off a gsxr upper wiring harrness for my tl gauges?:)
OOOOOooooh, That I'm not sure about. Here's a pic of the one on my 04 600 if it helps. Click for a big un.
I matched the pic of your plug to the back of my gauges and they look they are the same. I need batteries for my camera, I will post pic of my gauges later tonight.:)
I may have that plug if you need it.
Not sure, but let me know and I'll look.
Discussion Starter · #9 ·
ok thanks!!!!!!:)
Christ, I found it already.
It's just the plug itself not the harness, will that work?
Discussion Starter · #11 ·
I'll give it a shot, doesn't hurt to try right?:)
Does it look like the one in the picture?
Discussion Starter · #12 · (Edited)
well here's my gauges and the gsxr plug
So you're using GSXR gauges?
It looks like the one in the picture, but I'm sure you'll have to change the wires around if it's not going into TLR gauges.
If you want it, shoot me your address and I'll mail it down.
Discussion Starter · #14 ·
yes i would like it and it's going on my tlr gauges. the reason i asked if the gsxr one would fit was because i was having a hard time getting a tlr one.
I pm'd you my address. Thanks
