Hey All,
Every couple of weeks I'll go out to start the bike for my morning commute and it won't start. The bike lights up fine, fuel pump primes, starter turns over strong, but battery (brand new) nearly drains long before the bike starts. Once I slave it to my truck it fires right up. I ride it for about 20 minutes to the workplace (high rpms) but when I get there the battery is still nearly drained and the bike won't start. At that point, sometimes the fuel pump primes and sometimes it doesn't.
Please bear in mind that my question is focused on the TLRs charging capability and not the root cause of the random starting issue. You're free to suggest likely culprits if you like, and all help is appreciated, but I don't want the title of this post to be misleading. I can research this site for previous starting solutions at a later date. For now, I'm mostly curious why my pathfinder's 8 year old battery, when jumped, will charge enough within a few miles to start a 6 cylinder engine the next day, but the TLR won't charge a brand new battery enough to power a flashlight immediately after riding much further.
FACTS:
1. Both batteries are brand new. Starting/charging issue occurred with both
2. Bike always fires up instantly, hot or cold temps, for days/weeks at a time, then doesn't
3. I have a wire bypassing the clutch switch, but fuel pump always primes
4. My TLR is Yellow
[Battery Specs]
FACTS:
4. My TLR is Yellow
[Battery Specs]
