first of all, you take the caps lock off:coocoo
all you have to do is wind some narrow black insulation tape around the handle bar where the switch gear clamps the bar. dont put any where the throttle tube goes or the throttle will stick open. this will be obvious after you take the switch gear apart
Scooter hottie chauffeur
there should also be a little plastic tit in the upper housing.... that fits into a little dimple on the clip on.
if the little tit is gone, the electrical tape mod works too. Or quite often there is a set of switches on Egay
On my throttle, I drilled an 1/8" hole where the tit was, then pushed in a piece of 1/8" stainless rod. As the dimple in the bars is larger, I drilled an 1/8" hole in a piece of 5mm rod to shim it up. Works a treat, though is more time consuming than tape!
