1 - 3 of 3 Posts
Hey guys is this a common problem:O , when I roll off the throttle if i let the spring return the throttle the bike idles fine but then I can roll it off past that stop point and the bike stalls:O , it's a pain in the arse because under heavy breaking coming to a stop the bugger keeps stalling on me :coocoo
Any ideas to sort this out? or is it a TLR thing?
Adjust the freeplay between the cables (push/pull) reset the idle adjuster as needed...You should be able to do it at the clip on end,try the closing cable first.
Thanks TLDV8 will try that, I am not sure how much adjustment I have will have to check it out
1 - 3 of 3 Posts
