1 - 20 of 83 Posts
finally think I have turned the corner and stopped pulling things apart.:banghead
last night I got active with a big ugly file and took all the casting marks off my bottom trilple and then got into it with a few grades of paper. then i got it on the bench buff.
finally papered:
then after the bench buff:
Stripped down the frame and cleaned it up too and painted it with a super coarse silver metalic and a couple of coats of clear.
Now I just need start putting it back together. :devious
:thumbup nice
nice :)
Good score Stu
And some nice polishing too:bling
There isn't anything left to pull apart on that frame so I guess you'd better start putting it back together.
Keep updates coming. :thumbup
Looking Good Stu :thumbup
Be careful with the Duc Rad to make sure it doesn't sit in front of the cam cover or your front wheel will hit it on full bump/flex and send you over the bars :banghead
The SV1000 makes a nice Rad for a street fighter, alloy end caps etc
Mine was coupled to the TLR Bottom rad for cooling the extra pony's in Traffic, hard to find though :confused
Thanks for the heads up sam, My rad is knackered holds water but is as bent as a back street junkie. I like the idea of having a curved rad so we'll make it work
I started with the curved TLR top rad on mine but it didn't look right, mainly because the rad was shorter and there was a gap under the frame, if you can find a curved rad the same height as the TLS it would fit much better :thumbup
Rather than posting loads of pics here I can PM the various pics for ideas etc
Discussion Starter #12
cheers:
Frame and triples look :drool
Will the radiator shed enough heat to keep the 33% larger TL engine cool? Especially in balmy Australia... :O
Looks sweet so far:thumbup
I expect the rad will have enough cooling capacity - the 749 makes pretty near the same power levels as a TL so it should require roughly the same amount of cooling I would think.
PS, the Disc came, thanks:hail :banana :hail
Looking real good there Stu.
Ive been away for awhile. Was that your Red TLS? or you get another one
Discussion Starter #17
nope just trimming back the red one.
BTW have you got a rifleman cover on yours?
Discussion Starter #18
went to fit the front wheel last night and couldn't find the axle nut. turns out it is still in melbourne. Hats off to peter a Promecha it will be here tomorrow!!
BTW they did a nice job on my forks!!(plug plug plug)
Discussion Starter #19
Axle nut arrived and I took a trip to the bolt shop with a shopping list.
Popped the bolts and screws up in the lathe and tidied them up a bit and shes started the journey to togetherness.
Cap screws before:
And after:
modded bolts inthe triples and forks:
Reactions: Troy
Nice work Stu :hail You have far too much time on your hands :laugh
1 - 20 of 83 Posts
