All prices include S&H:
Stock clipons $40 for pair; $15 for the third one
Stock clutch cylinder w/ line & lever $65
Radiator overflow $30
Partial left rearset (broken lever) $10
Stock airbox (unmodified) $60
Stock exhaust header (Right side) $40
Stock exhaust header (Left side) $40
Flywheel $20
Stock RAM air ducts w/ rubber boots $40
Exhaust heat guards (x2; mild rash on one set) $15
Heads w/ cams $100
Windscreen (clear) $25
LE Forks $275 (Stock forks worked by LE for a ~200lb racer)
Triple tree $80
Stock right fork leg $40
Tank (perfect save for 2 tiny dings) $210
Coils $30
Throttle bodies $40
Stock Engine (~10k miles) $250 LOCAL PICKUP ONLY
Discussion Starter #2
test 2
Stock clipons $30 for pair; $15 for the third one
http://img505.imagesha
ck.us/img505/3384/dsc7201aq1.th.jpg
Stock clutch cylinder w/ line & lever $50
ck.us/img505/970/dsc7199lq0.th.jpg
/URL]
Radiator overflow $20
[URL=http://img5.imageshack.us/my.php?image=kml1042.jpg]http://img5.imageshack.us/i
mg5/8994/kml1042.th.jpg
Partial left rearset (broken lever) $15
http://img182.imagesha
ck.us/img182/5944/dsc7195ok4.th.jpg
Stock airbox (unmodified) $70
ck.us/img505/7382/dsc7204sp6.th.jpg
ck.us/img182/3599/dsc7196ym7.th.jpg
http://img398.images
hack.us/img398/1369/dscn8664s5ys.th.jpg
http://img398.imageshack.us/img398/2607/dscn8661s9ux.th.j
pg
Stock exhaust (Not including Slip-on Adaptors) $100
Exhaust Adaptor (Bolt-on Exhaust to Slip-on header) $100
http://img11.imageshack.us
/img11/4679/kml1034.th.jpg
http://img150.imageshack.us/img150
/5016/kml1036.th.jpg
http://img285.images
hack.us/img285/9904/dscn8659s2ck.th.jpg
http://img285.imageshack.us/img285/3651/dscn8657s1hh.th.j
pg
Stock radiator fan $25
http://img3.imageshack.us/i
mg3/8743/kml1038.th.jpg
Stock Heads w/ cams $100
Stock cylinder head covers $40
http://img291.imageshack.
us/img291/741/kml1037.th.jpg
Headlight (stock) $125
Tail-light (platic around it is cut)
Mirrors
Stock turn Signals
us/img150/5851/kml1018.th.jpg
Windscreen (clear) $20
Windscreen (dark smoke) 25
http://img149.images
hack.us/img149/1414/dscn8650s0pe.th.jpg
http://img149.imageshack.us/img149/2566/dscn8649s1qr.th.j
pghttp:/
/img162.imageshack.us/img162/5383/dscn8648s1bk.th.jpg
http://img348.imageshack.us/img348/5154/dsc
LE Forks $250 (Stock forks worked by LE for a ~200lb racer)
hack.us/img505/8154/dscn8598swn5.th.jpg
http://img505.imageshack.us/img505/4269/dscn8600ska3.th.j
pghttp:/
/img505.imageshack.us/img505/1889/dscn8602sxf3.th.jpg
http://img505.imageshack.us/img505/9031/dsc
Triple tree $60
ck.us/img505/1455/dsc7197et2.th.jpg
/URL]
Tank (perfect save for 2 tiny dings) $225
[URL=http://img398.imageshack.us/my.php?image=dscn8666s1nt.jpg]http://img398.images
hack.us/img398/4806/dscn8666s1nt.th.jpghttp://img398.imageshack.us/img398/1827/dscn8667s2jy.th.j
pghttp:/
/img368.imageshack.us/img368/3922/dscn8668s2qh.th.jpg
http://img398.imageshack.us/img398/1204/dsc
Clutch Plates x7 (part# 21451-02F10) $5 each
Clutch Plate x9 new (part# 21441-02F11) $8 each
Clutch Plate x1 old (part# 21441-02F11) $4
Clutch Springs x6 (part# 21413-02F10) $2 each
http://img17.imageshack.us
/img17/8535/kml1045.th.jpg
Coils $30
Throttle bodies $40
Graves Fairing Stay $60
mg3/514/kml1020.th.jpg
http://img440.imageshack.us/img440/565
8/kml1022.th.jpg
GP Tech Fairing Stay $80
/img17/1251/kml1023.th.jpg
K&N Air Filter (NEW #SU-0015) $60
/img11/6672/kml1025.th.jpg
Vortex Gas Cap $40
http://img509.imageshack.
us/img509/6250/kml1026.th.jpg
Stock Sprocket Cover $15
us/img150/4061/kml1027.th.jpg
HID Ballast with connectors (bulb doesn't work) $30
/img11/4837/kml1043.th.jpg
Wheels - Powdercoated with cush drive $300
http://img12.imageshack.us
/img12/1016/kml1059.th.jpg
Complete wiring harness $250
http://img8.imageshack.us/i
mg8/3623/kml1049.th.jpg
Rectifier $60
/img17/3529/kml1048.th.jpg
Subframe (with tip broken; see pics)
http://img16.imageshack.us
/img16/6818/kml1052.th.jpg
Undertail (mostly stock) $40
/img12/8579/kml1057.th.jpg
Coils $40 (pair)
http://img27.imageshack.us
/img27/4933/kml1051.th.jpg
MISCELLANEOUS (make an offer)
http://img24.imageshack.us
/img24/5931/kml1050.th.jpg
