I've had my TL1000R for a month now, it was dropped so I am converting it into a streetfighter project. I runs fine except one problem - the temperature always indicated _ _ _ which means I have no idea how hot it is. There is no FI fault code on the gauges for "temp malfunction"", I tested the sensor, input voltages etc and it was fine. I bought a set of second hand gauges thinking it was an indication problem but still no joy. Could it be the ECU that needs replacing? Any idea's? ECu is quite expensive, thought I would ask for some ideas first.
