I just checked the clearances on the rear cylinder(tlr). I've read about n seen pics of tappets cracking in the center where they ride on the cam. So I pulled the cams n found this:
The left exhaust tappet clearance measured at .007"(the one w/the ring). The book says .008"-.012".
I cannot feel the ring w/my fingernail, but have any of y'all seen something like this before? If so would you recommend replacing the tappet? Or have you run something like this after adjusting the shim back into factory clearance?
Bring it in to spec and ride it....
Just stuck a 295 shim in it and the .008" feeler fits n the .009" won't go. On to the front. Thank you.
I'll probably probably run it all summer n check it in the fall to see if anything changes.
looks fine
yes
can I have the old ones?
Beware front Cylinder buckets.
Picture from Henk.
look carefully at the bucket if you see circular cracks dump it and buy a new one.
