In the case of the TL, and most fuel injected bikes, the rev signal for the tach originates with the crankshaft sensor or the cam sensor. Then it is processed by the ECM and sent to the tach. Is the VFR fuel injected? Even if not, they must use a sensor somewhere. I'm not familiar with Honda's methods.
You wont' be able to measure the active signal going to the tach without a scope (or something similar). A multimeter might indicate that something is happening, but it can't show you the details. The signal will be a pulse train of some sort.
