SV650 K3 Water pump
1692 Views 1 Reply 2 Participants Last post by  The Ring-In
Evening.
Had a good look and cant find anything about doing the seals inside an sv650 waterpump. I've researched the job on the TL as I have that to do before spring on mine but I bought the girlie the SV for Christmas and while giving it the once over noticed water dripping from the water pump overflow pipe (on the underside of the pump) while the engine was running. I have the pump off and split in half but what seal am I changing? The white disc on the impellor or the one that seems to on top of a spring above the bearing(s)?
Has anyone done the job or is there a walk through on here and I've missed it? Any advice or links much appreciated :)
1 - 2 of 2 Posts
Its an assembly
go to a dealer and buy one
1 - 2 of 2 Posts
