1 - 12 of 12 Posts
Does anybody know or even tried to fit the one piece alloy clutch cover from the SV1000 on a TLR/TLS ?
Do away with the plastic one :laugh
Fiche-Man,
To start, sorry for my bad English...
I tried to adapt a TL casing on my SV1000S and they are not compatible.
The interior of the casing is different and one of the screws is not positioned identically. If you want, I can make you a photograph with a joint of casing SV posed on a casing TL
I was looking at a friends DL1000 - the side case cover and clutch cover is all one part. Would be a pita to access the clutch. Just looking at the two it apears they would be interchangeable but I've not actually tried it.
Yes please, I thought maybe the crank cases were the same and hence the cover would also fit :O
Not too bothered about clutch access, I want to transfer my window'd cover to my road bike and fit a solid alloy cover to the race bike for better protection.
Ey look, another Swiss Zoner.
All I can say is the SV cover is NOT compatible with the clear clutch covers.
you guys rock
:hail
imagine having to remove the wp impeller just to access the clutch :coocoo
you guys rock
:hail
And often, it is necessary to change the joint of water pump shaft bus if you dismounts it, you have a risk of oil leak because it is fragile. I already had this problem.:rant
Thankyou _GP_
Saved me a valuable lesson there, why would suzuki change the crank cases :O
Rufer, sorry I meant swap the billet clear cover and main cover over, not fit the clear cover onto the SV one :devious
I suspect the one piece cover is cheaper to produce. The two piece cover would allow a quick change of the clutch, which could be important in a racing situation.
But why change the interface between the side cover and actual crank cases:confused
Discussion Starter #12
I knew the SV heads had the engine mounts in different places, but I don't see why Suzuki would go to the trouble of re-tooling to change the basic crank case design after so much evolution of the 97 TLS cases to present day TLR cases :O
1 - 12 of 12 Posts
