1 - 20 of 28 Posts
I want to add a list of acronyms that Suzuki uses on its bikes to my webpages. I'll add some generic ones that apply to their bikes, but I'm mainly after the Suzuki jargon...
Off the top of my head to get the ball rolling:
Generic:
DOHC = Double Over Head Cam
ECU = Electronic Control Unit
ECM = Electronic Control Module
EFI = Electronic Fuel Injection
PAIR = Pulsed (secondary) AIR system
TPS = Throttle Position Sensor
Suzuki:
TSCC = Twin Swirl Combustion Chamber
SACS = Suziki Advanced Cooling System
SET = Suzuki Exhaust Tuning
SRAD = Suzuki Ram Air Direct
STVA = Secondary Throttle Valve Actuator
Cough up
Scooter hottie chauffeur
GPI = gear position indicator
GPS = Gear position sensor
TRE = Timing retardation eliminator
:devious :laugh
DILLYGAFF = Does It Look Like I Give A Flying Fug
BO'HICA = Bend Over ' Here It Comes Again (pronounced Bo' He-ka)
FUBAR = Fugged Up Beyond All Repair
SNAFU = Situation Normal, All Fugged Up
AEC= Automatic exhaust control (on the RG500 Gamma)
EACS=Electric Air Control System (On the RG250 Gamma)
SET=Suzuki Exhaust Timing (on the2006 Suzuki Boulevard M109R)
SDTV Suzuki Dual Throttle Valve
:devious :laugh
Now those, I undestand!:laugh
DLC - Diamond like coating
SAES - Suzuki Advanced Exhaust System
ISC - Idle Speed Control
SCEM - Suzuki Composite Electrochemical Materials
SAIS - Suzuki Advanced Immobilizer System
SASS - Suzuki Advanced Sump System (BOULEVARD M109R, RM-Z450, + others)
SAP - Suzuki Advanced Plating
SECVT - Computerised Suzuki Electronically-controlled Continuously Variable Transmission (Burgman)
CVT - Continuously Variable Transmission (Burgman)
Discussion Starter · #9 ·
Take your deltabox and EXUP out of this thread :laugh
TL = Ticks Loudly
Oh wait....that wasn't an "official" one. :laugh
What about Full Floater - for the rear suspension linkages when they first started going to the single shock rear and didnt Slingshot refer to the Square slide carbs :O
Discussion Starter · #13 ·
:laugh I had a "Slingshot" GSXR, it used to piss me off when people called it a slingshot :rant. Just like I cringe when I hear the word SRAD.
They were a CV carb that had half round slides in it. The pre "slingshot" models had the flatslides with accelerator pump.
Its probley my dirtbike years coming out but i think when the RM's come out as slingshots they had Flatside carbs.
Discussion Starter · #15 ·
Current models using Mikuni carbs are "Slingshot" carbs too. I have no idea what makes them a slingshot. :dunno
Discussion Starter · #16 ·
SACI - Suzuki Condensed Air Intake (Pre SRAD)
Discussion Starter · #18 ·
The FTaS is Fatter Than an "S" :coocoo
Not official that I know of, but lots of folks say
RM = Roger's Machine :O
Yeah Steve,
That SRAD moniker some people use to identify the GSXR is :puke
I've heard people say "SaaRad" "SooRad" "S Rad" but all I can do is laugh as it is so not rad to call a bike by it's induction system acronym! There are so many of these Suzuki acronyms I'm not sure you will ever get them all. Here's a few for your list. Off my 86' GSXR1100 you have quite a few. From the factory shop manual it describes the engine type as: four-stroke, air-cooled with SACS, DOHC, TSCC. If you didn't know the acronyms listed you would be SOL!
You can add "NEAS" which is used to describe the very non-functional electric anti-dive system found on the early GSXR forks. It refers to that little dark gold colored cylinder on the bottom, front of each fork leg. I just scanned the manual & it doesn't say anything about what this acronym stands for. The manual just tells you to be aware that the NEAS unit can leak fork oil & if it does you need to replace it. I am pretty sure what most of the acronym stands for; it is "Electric Anti-dive System" but the only thing I can come up with for the "N" is "Non-functional" or possibly "Nevermind the."
LOL
The brake calipers on that bike (both front & rear brakes) have plastic caps that go over the top of the caliper body. They have large "DOP" raised letters on them. That stands for "Dual Opposed Piston" or is that "Dinky Obsolete Piss"?
:laugh
1 - 20 of 28 Posts
