1 - 17 of 17 Posts
Although I’ve been riding a lot of years I’ve never really tampered with the standard settings on my suspension.
I have a completely standard suspension set up (as it left the factory, all standard parts, all standard settings (according to owner’s manual)) when I first got the bike it was set up really soft both back and front now I assume that the guy who owned the bike before spent a lot of time with her in doors on the back and neither of them was a “feather weight” and a comfortable ride was required.
Now as I said I’m a complete novice at this stuff so I’ll give all the details many of which are probably irrelevant.
I am 15 stone give or take a few pounds, I’m top heavy (32-34” waist 48-50” chest) and 5’8” tall. Should I set up the suspension and preload etc to a firmer setting to account for my weight? Also I do tend to ride quite hard, I don’t like cruising!! So would a firmer ride be more advantageous?
Thanks in advance
Work done so far;
Custom exhaust (not TLR)
Power commander 3
K&N filter
Gear indicator with built in TRE
Braided hoses
6 pot callipers
Custom rear foot pegs
Fairing lowers
LED Indicators
Paint job
Loads of other small things
For this Google can be your friend even YouTube, there's plenty of set up info to be found,some good instruction videos on YouTube
I upgraded my '97 TLS as follows: Bitubo rear shock ($550 USD) and Race Tech .95 Kg front springs with #5 fork oil and have found it a significant upgrade, if not a little on the stiff side for 'cruising'. There are a lot of TL owners who fit GIXER & 'Busa front ends on their bikes with little mods.
Best of luck with your TL.
Or save a fortune and fit a r1 damper in place of the rotary,and ask tls-ged if he's still got his gsxr forks for sale
Is any R1 damper ok to fit or do I need a specific year? is it a straight swap or do I need additional brackets or fixtures??
Possibly but only been down twice this year due to the appalling weather
Yeah, its been proper crap this year hasn't it.
Have a look at http://www.gostar-racing.com/information/motorcycle_suspension_set-up.htm
That will give you some pointers. I have some pdf's at home on suspension setup, I will try and find them for you. I think MH Racing in Chippenham used to tell you the exact settings for your weight for about 15 quid, but I couldn't find that on their website
Jeez just looked at that web site, its pretty involved. OK, I earn good money so where can I get someone else to set my bike up for me, either North Wales or North West generally? I am not sure my local Suzuki dealer is trust worthy enough to do it (many of the repairs etc they have done on my bike have been botched).
If you search for member adstl on here,he's doing the brackets
And for the r1 damper you need a 04-08 or you can use a 98-03 r6 shock like I've done,there's a few people done this mod now,there's a few threads on the subject of rear suspension, if you wanted to go for a full sprung shock you can get a Ducati 1098 shock shortened and re sprung and fit one of them, but you'd need the gap mod done
if north west is good for you give kais a ring they're in atherton near leigh they did my forks for me that and a maxton rear shock (i think theres one on ebay at present) sorted the bike out its planted everywhere now and i like yourself ride quite hard
website http://www.kais-performance.com/
phone 01942 896366
Discussion Starter #13
ok, so options are, buy an Ohlins with all brackets etc or buy an 04 onwards R1 damper and get brackets made up?
Nope..........
You can get a Bitubo which replaces the SOAS and the rotary dumper.....or....... get a Hagon shock, White Power (rarer than rockin' horse poo!) and there's another couple of brands that I can't remember :laugh
All depends on how deep your pockets are....
hello what you need to do is take it to kais and they do a ride in ride out 01942896366 even on saturdays ,I put a bitoubo rear shocker(ebay) on and then took it to kais for new springs and setting up,very diffrent bike and worth the money
Wilbers is around £650
GubellinI is around £500
They both replace the tls rear suspension
Hagon and ohlins just replace the damper you're looking at £300 - £800
Or go the R1 damper route and get it all done for £60
Discussion Starter #17
thanks for your help guys, I will keep you all up to date as to the route taken.
1 - 17 of 17 Posts
