1 - 3 of 3 Posts
When i first got my TLR there was NO surge at all but it was a bit of a handful around town.
After fitting a JeffW TRE there was still no surge and it made the bike LOTS better around town.
When i fitted my PCIII USB and loaded the map which was the closest to my configuration (M303-303 - Yoshimura bolt-on mufflers, Stock or aftermarket air filter) and activated the Fuel Pump Accelerator set to 90% Sensitivity, 15% Fuel Increase with a 20 Engine Revolutions Duration (Street Settings) the bike now pulls stronger but it's back to being rubbish around town and has an aweful glitch/[email protected] rpm :O :coocoo :confused :rant
Can anyone offer and tips/settings/advice?
I know ideally i need a custom map making but atm it isn't an option.
Thanks in Advance
Daz.
can you at least get a dyno run with gas analysis to check the fuel mixture?
it's jerky on steady throttle right? sounds like the map has made your bike lean at that spot but i think the acc. pump feature might mask it on a dyno:O
1 - 3 of 3 Posts
